Pulling flywheel by yourself while top end is off and motor is out of car
Old Jan 1, 2004 | 04:55 PM
v7guy's Avatar
having some serios problems here, I basically cant come up with a way to keep the rotatin assembly from spinning while trying to take off the flywheel, tried everything I can think of, anyone have suggestions?
Old Jan 1, 2004 | 05:06 PM
funina91ss's Avatar
wedge a hammer handle in the whole on the fly wheel or use and impact to take them off. Either way works. Imapct is alot easyer if you have one.
Edit- You have M6 I guess. try to put a pry bar inbetween the starter teeth and block. It will be hard to do with one person but that is what it will take. Might try a flywheel turner too.
Old Jan 1, 2004 | 05:09 PM
Beast96Z's Avatar
If it is the stock flywheel, you can put a smaller diameter screw driver through one of the holes on the outer edge of the flywheel. Rotate it counter clockwise till it lodges against the block. You should then be able to break the bolts loose with no problem. This is the way I do it anyway.
Old Jan 1, 2004 | 05:50 PM
v7guy's Avatar
it look slike the screw driver will work, I'll pick one up tonight from work, thanks
Old Jan 1, 2004 | 07:31 PM
jonaddis84's Avatar
Wait, let me get this straight....you have an engine out of your car totally dissassembled....and you dont have a screwdriver?!?!
I like the impact wrench idea, but if you dont have a screwdriver you most likely dont have an impact, impact wouldnt require the flywheel being held still.
Old Jan 1, 2004 | 07:48 PM
v7guy's Avatar
LOL yeah that would be the case, all I have is this big beefy brawny screwdriver with no way to fit in through a pressure plate hole, the irony is amazingly humorous, and of course no I have no impact wrench
Old Jan 1, 2004 | 10:13 PM
jonaddis84's Avatar
http://www.jegs.com/cgi-bin/ncommerc...97&prmenbr=361
Jegs part # 555-80530
Flywheel turning tool, basically your only option unless you happen to have an air compressor, then buy yourself an impact for $39.99
cmdeshon
Dec 12, 2014 10:51 PM
siguy
Nov 27, 2014 10:07 AM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
