Pulling the engine from the top
Old Mar 9, 2005 | 10:12 AM
ricoace's Avatar
I have done a search on this topic and found some good info. Can anyone explain to me in detail the procedure for pulling the engine from the top? what makes it harder?
Old Mar 9, 2005 | 10:54 AM
396D1SS's Avatar
Re: Pulling the engine from the top
I always pull my engine from the top. even with the hood on, you got to take off the acc bracket and remove the harmonic balencer and hub
BlownF1's Avatar
Either method works fine, but pulling from the bottom is "easier" in my opinion because you can leave 90% of the stuff attached. Having the headers, plug wires, etc fully dressed before reinstalling it is a major plus. There's lots of step by step pictures of each so I won't bother with the details. Check out Brent Frankers f-body install guide, there's probably at least a few in there.
Old Mar 9, 2005 | 11:07 AM
Dave88LX's Avatar
Having pulled it from the top, and also dropping it out the bottom, I found going in/out the bottom is SO much easier and convenient than through the top. There's no real advice to give about coming out the top than "disconnect everything and get everything out of the way. It's a PITA, I'll never go out the top again.
Old Mar 11, 2005 | 08:37 AM
ricoace's Avatar
Thankyou for the replies. I guess I am just too old school, I think I will take it the safer road and pull it from the top.
calaban
May 18, 2020 06:43 PM
Gtpguy
Jan 26, 2015 04:50 PM
siguy
Nov 27, 2014 10:07 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
