Pulleys? yes/no
Old May 31, 2006 | 10:12 PM
frankthetank078's Avatar
Pulleys? yes/no
i was talkin to my transmission guy about pulleys and he said that they arent a good idea because of the system i have in my car...i mean the guy does no a hell lot about cars but is that true? and are the gaines worth it? thanks
Old May 31, 2006 | 10:15 PM
Moshbmx1's Avatar
Re: Pulleys? yes/no
Pulleys are going to make the components that run off the belt spin slower. If you are running a big system that requires a lot of power then you may want to be careful. Things like the alternator will run slower and wont create as much amperage as often.
Old Jun 1, 2006 | 12:19 AM
Misfits's Avatar
Re: Pulleys? yes/no
i have a system in my car, i bought march pulleys, i believe there r 2 catergories, performace and huge amperage requirements, and i've had it for over a year now and no problems. jus check out there site, march pulleys.
Old Jun 1, 2006 | 12:29 AM
1995greenTA's Avatar
Re: Pulleys? yes/no
You would probably get a faster car by pulling out the system than by bolting on underdrive pulleys. Why do you need music to hide the amazing sound of a small block chevy? Just my opinion
Old Jun 1, 2006 | 12:41 AM
slow95camaroz28's Avatar
Re: Pulleys? yes/no
i need music to hide my gear whine
Old Jun 1, 2006 | 08:17 AM
matt65's Avatar
Re: Pulleys? yes/no
My vote is no on the crank only pulley from March. I tried them once myself and the electrical load at idle was obvious.
If you do get a set of pulleys I woudl suggest the crank pulley that has the balancer built in. The piggy-back setup only ands rotating mass.
Old Jun 1, 2006 | 09:45 AM
OBE1 95Z28's Avatar
Re: Pulleys? yes/no
Pulleys have very little bang for the buck; spend your money elsewhere (been there, done that).
Old Jun 1, 2006 | 11:31 AM
Re: Pulleys? yes/no
Listen to this guy
Instead of pulleys, do a throttle body bypass. probably get the same gain. Keep your extra money for the topless bars
Old Jun 1, 2006 | 11:51 PM
Misfits's Avatar
Re: Pulleys? yes/no
Originally Posted by 1995greenTA
Listen to this guy
i did both the tb bypass, pulleys, crank and alternator at the same time, and it pulls incredibly stronger..
Old Jun 2, 2006 | 12:11 AM
user 647483's Avatar
Re: Pulleys? yes/no
ditto
Old Jun 2, 2006 | 07:20 AM
WhyHelloOfficer's Avatar
Re: Pulleys? yes/no
Incredibly? Are you serious?
My opinion on the pulleys is to save the money and apply it elsewhere.
Old Jun 2, 2006 | 07:28 AM
Re: Pulleys? yes/no
No substitute for some real-world data:
http://www.ws6.com/mod-2.htm
Putting an underdrive pulley on the crank, and then putting an overdrive pulley on the alternator will give back some of the limited gains. Going with underdrive on both the crank and the alternator caused charging problems at idle with my car, and the only extra load on the electrical system was a second fuel pump.
Old Jun 2, 2006 | 11:47 AM
93redBirdMan's Avatar
Re: Pulleys? yes/no
Ive got the underdrive pulley on my crank and the overdrive on my alternator and I still have some charging issues. BUT the charging issues don't seem to affect anything... I only installed them because I got it all for $40... I wouldnt pay full price for pulleys...
Old Jun 2, 2006 | 08:03 PM
besz28's Avatar
Re: Pulleys? yes/no
yes if all the other bolt ons are done....why not
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
