Are pulleys worth it?
Old Feb 28, 2003 | 10:43 AM
  #16
BUBBA's Avatar
Have the March 2-pulleys on my SS m6. No problems to date. Actually think I gained a little better throttle response.
Theoretically, less parasitic drag should put more power to the rear, but not an engineer, so take it for what its worth. JMHO
Old Mar 1, 2003 | 08:18 AM
  #17
1fast95Z's Avatar
Originally posted by anaik
Stock waterpump is driven by the cam. Pulleys have no affect
No, you misunderstood. I realize that the waterpump is driven off the cam, my question was, for those people who have switched to an electric pump, there is no longer the parasitic drag associated with the waterpump, so would you see more hp with an electric pump AND pullies?
Old Mar 1, 2003 | 08:26 AM
  #18
AlexBarabas's Avatar
Would the alternator provide enough current for the electric water pump and all the other stuff after the pulleys? This could be interesting... what about getting a higher-performance alternator that generates more and has less resistance (more efficient), getting pulleys, and then switching to an electric water pump? I doubt it's worth the hp for most of us but it might be worth looking into.
Old Mar 1, 2003 | 08:43 AM
  #19
FastZinTennessee's Avatar
Originally posted by scoobie30th
I couldnt tell you about the HP but i can tell you i went a 9.041 @ 79mph with 2.18 60' in the 1/8th with the only mod being an ASP underdrive pulley. I know some people will say " wow sarcasticly " because everyone here is faster
Don't feel bad, just compare yourself to what else is out there. We have a track here that's slow unfortunately. I ran a 9.15@79 stock. Now I run a 9.0@82 with current bolt ons. That last time is with me completely letting off the accelerator on the 1-2 shift so I won't kick the rear end sideways However that 9.0 was enough to handle all the LS1s at the track last time, except for one with bolt ons and drag radials.
John
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
blaze309
Sep 8, 2015 05:27 PM
colts0455
Sep 2, 2015 12:41 PM
mark0006
Aug 29, 2015 09:45 AM
