Pulled the heads, some carbon stuff fell into cylinder. Use carb cleaner to clean it?
Old Sep 12, 2004 | 10:35 PM
BlackLT1_TX's Avatar
I pulled the heads, the side that was leaking had some coolant in it, I used some shop towels to soak it up. But now looking into them, there is like grainy carbon stuff that had fallen in there. I was very carefull when I was doing it, but I think it was unavoidable. Also, I definitly found the chamber that the gasket failed on. The piston is nice and clean, and that chamber looks different then the other chambers. So, will everything be alright?
Also, I might need to make a second post for this, but has anyone re-bearinged a motor while it is in the bay? I have most everything out and I am doing a cam swap w/105k on the ticker.
THanks,
James
Old Sep 12, 2004 | 11:14 PM
Re: Pulled the heads, some carbon stuff fell into cylinder. Use carb cleaner to clean it?
A shop vac will suck any loose debris out of the cylinder.
Old Sep 12, 2004 | 11:28 PM
Should I then put each piston to the top and clean it out with some carb cleaner and a shop rag, to get the little stuff out?
Old Sep 13, 2004 | 12:05 AM
96speed's Avatar
I would..why not .
Ryan
Old Sep 13, 2004 | 10:02 PM
arnie's Avatar
I too, like to use a vacuum cleaner.
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
thenewkid
Nov 27, 2014 09:41 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
IgorT.455/406
Jun 4, 2003 03:32 AM
