Pull valve cover???????
Old Jan 26, 2006 | 08:16 AM
Heatmaker's Avatar
Advanced Member
I already knwo the answer.... but maybe someones more clever.
Can you pull the Passengerside Valve cover off with the altinator in place?
Old Jan 26, 2006 | 08:50 AM
LiENUS's Avatar
Re: Pull valve cover???????
No, you can't, but the alternator only takes a short amount of time to take it off, I took mine off helicoiled it, and put it back on within 15 minutes, the hardest part was doing the belt. And I might add it was my first helicoil i've ever done.
Old Jan 26, 2006 | 09:09 AM
wrd1972's Avatar
The ALT can be pulled in less than five minutes.
Old Jan 26, 2006 | 09:24 AM
OBE1 95Z28's Avatar
The belt comes off easily, 13mm socket and a long handled ratchet or breaker bar on the tensioner center bolt.
Old Jan 26, 2006 | 09:39 AM
Heatmaker's Avatar
Advanced Member
Trust me I know, I just forgot to bring my jacks with me.... damn... time to pull this thing off again....
Old Jan 26, 2006 | 11:52 AM
LiENUS's Avatar
The belt took me the longest because i had the car on the ground. I don't even use a long handled ratchet for it. I have a little stubby ratchet I use.
Old Jan 26, 2006 | 12:50 PM
OBE1 95Z28's Avatar
Quote: "I have a little stubby ratchet I use."
Leverage is your friend
Old Jan 26, 2006 | 01:35 PM
94Camaro_Z_28's Avatar
13mm wrech is what I use....and if you're limber, you can get it from the top
Old Jan 26, 2006 | 02:42 PM
1995greenTA's Avatar
LiENUS HAS A LITTLE STUBBY!!!!
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
