Pull valve cover???????
Re: Pull valve cover???????
No, you can't, but the alternator only takes a short amount of time to take it off, I took mine off helicoiled it, and put it back on within 15 minutes, the hardest part was doing the belt. And I might add it was my first helicoil i've ever done.
Originally Posted by OBE1 95Z28
The belt comes off easily, 13mm socket and a long handled ratchet or breaker bar on the tensioner center bolt.
Originally Posted by LiENUS
The belt took me the longest because i had the car on the ground. I don't even use a long handled ratchet for it. I have a little stubby ratchet I use.
LiENUS HAS A LITTLE STUBBY!!!!
