Puddle of fluid on ground after header install
Old May 21, 2009 | 09:50 PM
H2O's Avatar
H2O
I just went under the car after a few heat cycles and noticed a 2" diameter puddle of what I think is water on the drivers side right after the o2 sensor. This is where the y pipe is clamped into the header collector. I smelled it and it seemed oder less. I assume its condensation, but it seems like a lot. The pipe is clamped on with a U clamp and welded in 4 spots so it would be easy to remove without cutting. The bolts for the clamp are wet with the same fluid. Just drops and its not oil for sure. I dont see any moisture on the exhaust tips.
There is no smoke at all out the back so I highly doubt it is a head leak. The motor runs very strong and as of now has no exhaust leaks. It was 85* today but little humidity.
Some more info, sure its not pertinent, I am running Pacesetter LT's with no AIR, no Cat.
I do not have A/C at the moment. So its not from the that. Plus it is on the DS.
Opinions? Obviously I will keep an eye on it. Problem is I am a glass half empty kinda guy and assume the worst.
I hope it is just a result of the new headers breaking in.
Jim
Old May 21, 2009 | 10:09 PM
97'Z-28's Avatar
you kinda answered your own question.
I bet its just condensation.
Old May 22, 2009 | 07:35 AM
DAVE00's Avatar
Do you still have A/C on your car as this is the exact spot near the firewall that the condensor drains - see the pic below from Shoebox's web site:
Old May 22, 2009 | 09:13 AM
H2O's Avatar
H2O
A/C is on the car, but it has no oil or freon in it as I had to remove the hose that was cut in half. Plus the drain is on the passenger side.
If it was condensation, it sure seems like a lot. Plus if the pipe is on tight and sealed for leaks, then why is it leaking? I mean if water can get past it then so could exhaust= leak?
Old May 22, 2009 | 05:23 PM
The exhaust is made up primarilly of three components - water vapor, CO2 and nitrogen. Cold starts and frequent cold starts can cause a huge accumulation of water in the exhaust system. If your clamp is at a low point, and not quite as tight as you assume, its likely that's where the accumulated water is running out.
PCLZ28
Dec 24, 2015 05:19 PM
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
Collector Car
Jan 5, 2015 10:58 AM
Jul 4, 2005 05:00 PM
