Pros and Cons of gapless rings (ZGS)
Old Sep 5, 2005 | 07:03 PM
  #16
1racerdude's Avatar
Re: Pros and Cons of gapless rings (ZGS)
Got experience with Total Seal gap less top and C&A gap less second.
A gap less second don't work well in a race engine because if ANY compression gets by the first the gap less second will hold it in and unseat the top ring.This is why knowledgeable builders today put more gap in the second ring.
I have had no complaint's with the Total Seal gap less top.My theory is once it gets by the top ring you are done.
Don't know about other's may have been installation error or machining error. Along with advice from Total Seal I have found what works.
Old Sep 5, 2005 | 09:02 PM
  #17
Fbody1's Avatar
will the cast( or iron)rings ,if I use them for top and second, be hard on the cyl walls ? this is going to be a street car so I would like some performance , but need be reliable.
Old Sep 5, 2005 | 09:08 PM
  #18
1racerdude's Avatar
Ductle iron will not hurt the walls,neither will a gapless top ring.
Old Sep 5, 2005 | 09:14 PM
  #19
SStrokerAce's Avatar
Ditto here
Old Sep 5, 2005 | 10:01 PM
  #20
MachinistOne's Avatar
I did a little reading on total seal, and all their ring packs except for the race set use gapless second rather than primary... Why do they recomend the ZGS for the street if the primary has all the advantages and no weaknesses?
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
