Proper way to prime the LT1 oil pump
Re: Proper way to prime the LT1 oil pump
With modern day oils I believe "priming" is a bit archaic. A good smothering of moly lubes like Mobil 1 during assembly will protect the engine on start up.
The only thing I recommend is filling the oil filter with oil before install.
You'll be fine.
You'll be fine.
You'll be fine.
You'll be fine.
Originally Posted by dynomight
collar.
Okay, Engine builders what about the Melling pump and the pickup and drive shaft.
I heard something about spotwelding it as they can get loose and fall in the engine/oil pan and stop pumping oil (logical) ???
Well, the Melling HO pump for the Lt1 always comes with a seperate pickup and seperate shaft as far as i was able to see on the internet.
It doesn't have to be a Melling,there are good pumps out there that come assembled.
Originally Posted by Black1995Z
So I can prime the oil pump by starting the car with the opti harness disconnected or by removing the pcm fuse?
How long will this take approx?
It can take what seems to be a long time when starting out with a dry pump. That's why I like the primer.
Originally Posted by shoebox
Until there is oil pressure.
