Proper way to flush oil?
Old May 5, 2009 | 02:05 PM
97BBlackZ's Avatar
Changed out my head gasket and some coolant got down in the cylinders. Thought i cleaned it all out but apparently some got in the oil.
Ran it for 5 mins then changed the oil and it was milky.
Just wondering what the proper steps are.
Currently i'm draining all the oil and running a few quarts down the valve covers till its clean then going to run it for 5 more min and change the oil again.
Would this be the proper way. Or do i need to get some kind of motor flush to be sure?
Old May 5, 2009 | 02:23 PM
wrd1972's Avatar
Multiple oil changes is the right way IMHO to flush the oil system out. Never use chemicals or bye bye bearings.
Old May 5, 2009 | 02:25 PM
97BBlackZ's Avatar
Cool.
Problem solved then
Old May 6, 2009 | 12:28 AM
itSSlowZ28's Avatar
might try some motor flush a time or 2. could probably speed the process up
Old May 7, 2009 | 08:31 PM
The_Bishop's Avatar
Do not use Motor Flush. That crap is just kerosene in a can.
Old May 7, 2009 | 09:05 PM
96capricemgr's Avatar
If you drained the oil refilled then started and it got milky already I have to wonder if there still isn't a leak.
I vote drain it again and if it is still milky I think that says still a problem.
Old May 8, 2009 | 09:01 PM
redcamaroz28's Avatar
1-2 oil changes after doing the head gaskets is all that's needed. When doing the oil changes, just take the filter and plug off and let it drain for about 10-20 min. Fill it back up with oil and you'll be set. DO NOT use any type of engine oil flush. As stated above, alot of that crap out there kills bearings.
FredM
Jun 5, 2015 05:45 AM
dylan1303
May 22, 2015 12:24 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
kksi
Feb 17, 2015 10:41 PM
Sandersen511
Jan 13, 2015 03:49 PM
