Proper pushrod length checking
Old May 15, 2006 | 07:44 PM
  #31
Jeff95TA's Avatar
Re: Proper pushrod length checking
The Car Craft method doesn't address the thickness of the mark. It just makes a thin line where the START of the mark would be. So if you use that method (which probably isn't the best), then that thin line should be towards the intake side.
Old May 15, 2006 | 07:57 PM
  #32
Javier97Z28's Avatar
Moderator
Ok, thanks Jeff, that's what I thought it was doing, but wasn't sure. Using that method the line is in the center anyways, which is obviously "too late" for the starting point
So method you are using to get the above results you showed is what I'm doing:
"solid" lifter
set lash AND preload (1/8 turn here)? or with a solid lifter is there no preload, just zero lash?
rotate engine
check pattern
gah.. just realized I shouldn't have set "preload" on my solid lifter.. only for hydraulics..
Old May 16, 2006 | 08:11 PM
  #33
firebirdStud's Avatar
haha NO preload.. lol. I just measured my pushrod length today... thanks to this thread and Ron from AI I made my own solid lifter by gutting it and puttin a bolt in it so the cup hieght was the same as my comp oness. Worked slick. I ended up with 7.150. With heads shaved .020, block decked .020, .027 cometic head gasket, and .050 longer ferrea valves. So not bad, and I am glad I checked it!
Old May 16, 2006 | 09:26 PM
  #34
A/G's Avatar
A/G
Originally Posted by firebirdStud
haha NO preload.. lol.... I made my own solid lifter by gutting it and puttin a bolt in it so the cup height was the same as my comp ones.
Are those comp lifters solids or hydraulics? If hydraulics, did you allow for preload in the (correct spelling) height measurements of your solid checking lifters?
Old May 16, 2006 | 10:28 PM
  #35
awe shart! no I didn't. But, I will only be runnin 1/4" preload. So, with the fine threads, it won't be too bad. I actually could have run the 7.2 but I opted for 7.150 after talkin with Ron. So, I should be good there!
Old May 16, 2006 | 10:33 PM
  #36
1racerdude's Avatar
The way ya said ya did it will be fine. 1/4 turn ain't gonna make ya or break ya.
Old May 16, 2006 | 11:36 PM
  #37
1racerdude's Avatar
Re: Proper push rod length checking
When most companies offer off the shelf push rods at .050 length difference,how ya figure .020 is gonna hurt.
I get mine made to the length I measure but most people don't and get PR's in .050 length differences and they ain't on the side of the road with PR's all hanging out the valve covers. Those big Co's must figure is not important enough to worry about if it's in .050 length increments.
Old May 17, 2006 | 03:51 AM
  #38
Victory Racing's Avatar
This is why I love being 15 minutes from our nations largest pushrod manufacturer, and their mine all mine.
Well at least at my disposal.
Old May 17, 2006 | 09:03 PM
  #39
89TramsAmGTA's Avatar
Hehehehe. I'm not that far from Manton Pushrods. I bought the adjustable pushrod from Comp Cams. I also like the device that slips over the stud. I think I will buy one of those also.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
