Proper Method To torque ARP Rod Bolts (Eagle I beam)
Old Feb 25, 2009 | 03:49 PM
ENRKyle20's Avatar
I did a full rebuild of my 95 camaros LT1 and I used eagle I beam rods and ARP 12pt head rod bolts. When I installed them I used stock torque specifications not thinking about it. Well now I have 37 miles on the motor and one of the rod bolts is working its way out and hitting the block. So I need to support the engine, Drop the k-member, pull the pan off and re torque them correctly. does anyone have the correct procedure?.. I would asume its gong to be a multiple step torque sequence followed by a torque angle maybe?..
Thanks for the help
Edit: More Info
5.7" 5140 steel SIR bushed rods with ARP bolts (SIR5700BBLW), (12pt cap screw)
Old Feb 25, 2009 | 04:02 PM
Kevin Blown 95 TA's Avatar
Well a lot of guys just torque them and forget about it, but using a stretch gauge is the best way because torque can be fooled by friction. You want to know the preload on the bolt, not how hard it was to tighten it. Also some racers will measure the fatigue of the bolts by checking the stretch to see if the bolts are getting too long.
LeftoverChinese
Jan 14, 2024 03:03 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Catmaigne
Dec 25, 2014 12:16 PM
