proper LT1 cooling system bleeding
Old Jul 10, 2006 | 10:27 PM
Dansean1's Avatar
guys...long story short. I have air in the system. What is the exact procedure for bleeding it? There are two bleed screws, when does one use them exactly?
I heard that one should put the car on an uphill slope so as to draw air to top of radiator and hoses, then turn on car, let it warm up with radiator cap off, but when does one open the bleeders? What is the difference.
All stuff I have researched is not specific.
Old Jul 10, 2006 | 10:30 PM
Re: proper LT1 cooling system bleeding
If the system is already filled, you merely open the bleed screws when the system is under pressure and close them when nothing but coolant comes out. There should be no bleeding necessary unless the system has been opened for service (just taking the radiator cap off does not count ).
Old Jul 11, 2006 | 08:15 AM
93transam1234's Avatar
And becarefull not to get the opti wet
Old Jul 11, 2006 | 09:48 AM
ulakovic22's Avatar
With the car running and up to temp open radiator cap and make sure your fluid is full. If it is then put the cap back on and open the bleeder screws until you see a steady stream of coolant. You can do them one at a time or both at the same time, it doesn't really matter.
Old Jul 11, 2006 | 10:16 AM
SixSpeedShifter's Avatar
Ummm.....you never want to open the radiator when the car is at running temperature. When the car is COLD, check the fluid level. Install the radiator cap, bring the car to operating temperature, open bleeder valves until pure coolant comes out, close valves. The end.
DirtyDaveW
Dec 1, 2016 05:37 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Collector Car
Jan 5, 2015 10:58 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
