Proper fuel pressure for my car
Old Oct 4, 2010 | 10:18 PM
Jon_Esslinger's Avatar
I have a 94 Z with an LT1, signature has the rest. I was having some running issues and I hooked up a gauge on the fuel line and it reads like 48psi. That seems way too high to me. I have an adjustable holley fuel pressure regulator. What exactly should I be at?
Old Oct 4, 2010 | 10:33 PM
After reading other posts I think I'm fine.
Old Oct 5, 2010 | 05:14 AM
Depends whether you measured the pressure with or without the vacuum line.
At idle, remove the vacuum compensation line (plug it to prevent a vacuum leak). Set the pressure to 43.5psi. Reconnect the vacuum line. Pressure should drop proportional to intake manifold vacuum.... about 6 to 8psi drop with a stock cam, less drop with a more aggressive cam.
Old Oct 5, 2010 | 09:25 PM
MikeGyver's Avatar
Set the fuel pressure at 43.5psi with the vac line disconnected, then fine tune your 42#/hr injector constant until your long term fuel trims are as close to zero as possible when cruising.
nophix
Nov 30, 2014 10:26 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
Burn_Out
Aug 18, 2002 08:49 AM
