Proper Coolant System Bleeding Procedure
Old Apr 15, 2006 | 06:53 PM
spm4520's Avatar
Can some one tell me the proper way to bleed the coolant system? Are you supposed to do it running? Hot or cold? Sequence of bleeder valves? Etc...
Old Apr 15, 2006 | 06:56 PM
BradcTA's Avatar
Re: Proper Coolant System Bleeding Procedure
After sraining all the coolant open up BOTH bleeder screws and fill the radiator with coolant until water comes out of both of the screws.
Old Apr 15, 2006 | 07:09 PM
MENEGRANDE's Avatar
check shbox.com
Old Apr 15, 2006 | 07:25 PM
6SpdLT1Z's Avatar
yup, car needs to be running w/ bleeder screws open, i recomend doing one at a time to make sure you don't get any coolant/water on your opti.
Old Apr 15, 2006 | 07:28 PM
6SpdLT1Z's Avatar
Originally Posted by MENEGRANDE
check shbox.com
http://shbox.com/1/4th_gen_tech2.html#radflush
Rod Bender
Nov 7, 2023 02:30 PM
blac94Z
Feb 15, 2021 09:43 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Collector Car
Jan 5, 2015 10:58 AM
Rod Bender
Jan 3, 2015 03:15 PM
