probles at high RPM's
Old Sep 9, 2003 | 11:19 PM
5.0 EATER's Avatar
It is a 1994 Trans AM
If I let my car sit over night it will drive fine. But soon as I start it agan, right at 3,000 RPM's it will drive rough. It will cut out and have no power. It tries to back fire and some times it does. But if i let it sit over night the next day it will be fine till, i kill it and start it. Please HELP!
Old Sep 9, 2003 | 11:20 PM
WheelmanZ28's Avatar
Sounds like your in the market for some new plugs and wires.
Old Sep 9, 2003 | 11:27 PM
NiteRider's Avatar
While you change that might want to change the ignition coil as well.
Old Sep 9, 2003 | 11:33 PM
5.0 EATER's Avatar
I have some miles on those plugs, I am sure that is what it is, thanks for the tip.
I never put plugs in a LT-1 is it a bitch?? Thats what i hear.
Old Sep 9, 2003 | 11:38 PM
Fatdog's Avatar
Cool
Only be sure the car is cold(cold heads),before doing the plug change.Do the coil wire first though.My02
Old Sep 9, 2003 | 11:40 PM
NiteRider's Avatar
It's not going to be easy, you might want to think of alternate ways of routing your wires to, over the top looms or some other fancy method.
I took my taylor 8mm's right through the stock looms but the next time I tackle them they will be going over top. Do a search on the board and see if you can find some pictures and just see what you like.
Old Sep 10, 2003 | 04:01 AM
revtime's Avatar
No need to go OVC unless you have headers.
And yes the plug and wire change is a PITA.
You will just have to suck it up and take the pain, just like the rest of us did.
blac94Z
19
May 13, 2015 04:50 PM
lt1matt
Mar 21, 2015 07:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
1996LT1Z28
Mar 8, 2015 08:16 PM
PhantomTA
Aug 17, 2002 12:19 AM
