problems turning over
Old Dec 19, 2016 | 08:53 PM
Rude boy79's Avatar
Ive got a 94 Lt1 and it recently died on me. I replaced the batt, alt, and popped in a new starter. but still am only getting a single click . need some advise on what else the problem may be.
Old Dec 20, 2016 | 09:58 AM
94Z28LS1toLT1's Avatar
Re: problems turning over
Um sounds like a ignition switch problem,or probably a ground wire. I remember my 94 same as urs did that I was at a light and the car just turned off n i was only getting a clicking.
Mine turned out to be a ground wire connected at the bottom side of motor was brOken,i put in a new terminal for the wire n my motor turned over
Old Dec 20, 2016 | 10:38 AM
Chimera96's Avatar
your battery cables are likely toast...
Innovative Wiring LLC
Old Dec 20, 2016 | 10:40 AM
Could be as simple as corroded strands in the main battery cables. Did you check them, and clean any corrosion off the terminals before installing the new battery and starter?
Shoebox has some info on the ignition switch. See if the first paragraph describes what you are experiencing.
4th Gen F-body Ignition Switch Replacement
Old Dec 20, 2016 | 01:05 PM
Rude boy79's Avatar
Yeah i cleaned all grounds, even got new post for batt. the cables are newer so i guess its on to the ignition.
Old Dec 20, 2016 | 11:11 PM
Fatdog2's Avatar
Just throwing this out there but is the key in good shape?I had my ignition switch in the column replaced under recall for saturn and got two new keys last spring and last month my saturn wouldn't start sometimes so I am using the other key they gave me with no problems(knock on wood).Hope this helps.
