Problems with taking off the upper panhard rod?
Old Nov 23, 2004 | 12:29 PM
Formula03's Avatar
Problems with taking off the upper panhard rod? I was thinking of taking it off to make room for some larger exhaust, I know I could get a relocation brkt but what would be affected if I took it off? Would it be that bad?
Old Nov 23, 2004 | 01:35 PM
MentalCaseOne's Avatar
Re: Problems with taking off the upper panhard rod?
Not sure I get the full meaning but.... are you just gunna temporarily remove it for the exhaust installation? or you wanna do away with it?
on a temporary basis... once you remove that bolt.. if the car shifts just a bit you gunna need a buddy to push the car back into aligntment before you can put that bolt back up. Else you will need a press and lots of grease to reinstall that freaggin bolt. I learned the hard way and its due to the bolt design.
Now if you just simply wanna remove the panhard. "period"..... your wheels will go one way while your car goes the other way in the first turn you make.
Marvin
Old Nov 23, 2004 | 01:46 PM
Mikey97Z's Avatar
Marvin
He said the UPPER bar. I've seen it removed before for custom exhaust. Not sure if there's any side-effects.
Old Nov 23, 2004 | 02:34 PM
mongse_1's Avatar
The only side effect I had was that I tripped over it a couple times when it was sittnig on my garage floor.
I wouldn't recommend it for a car that does a lot of cornering (road race/autoX) unless you brace the mounts some other way. It's debatable for a street car.
Old Nov 23, 2004 | 02:45 PM
***He said the UPPER bar. I've seen it removed before for custom exhaust. Not sure if there's any side-effects.***
Dang I missed that "Upper" part in the sentence or didnt I?
Sorry.
Marvin
silver97Z
Sep 11, 2002 03:17 PM
Skull Leader
Aug 10, 2002 11:01 AM
PaulN64
Aug 8, 2002 05:39 AM
PaulN64
Aug 7, 2002 06:17 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
