Problems with shifter moving out of PARK! (Has to do with brake pedal I think!)
Old Nov 24, 2003 | 05:29 PM
BlackLT1_TX's Avatar
I did Shoeboxes cable adjustment, but no luck. Today I found that it is related to the brake pedal. If I get it to shift out of park (by force) it will shift fine, and when I return to park, it will shift fine out, unless I let out the brake pedal and push it back in. Then it is stuck again.
So here is a simple way to look at it.
first - i get in and push the brake, and have to force the button in and finally get it out of park.
second - i get where i am going, and return it to park.
third - i keep the brake in from when i returned it to park and shift out of park and it is fine
fourth - i return to park and let brake out, then when i push the brake back in, i have to force it out of park
So it obviously has to do with the brake releasing it to shift out of park, but I have no clue what to do about it.
Thanks,
James
Old Nov 24, 2003 | 06:48 PM
ttt
Old Nov 24, 2003 | 06:53 PM
Fallchild000's Avatar
I have been having this problem for a long time now. And i have no idea what it is either. But yeah that shifter button just will not budge sometimes. I think it has to do with the car being cold, because in cold snaps it gets harder and harder to do. BUt when i cant move it, if I let the car warm up, it will eventually work.
I dont get it!
Nathan
Old Nov 24, 2003 | 06:56 PM
dude we have the idenical problem, that is exactly how my car is, EXACTLY!
I would think Shoebox would know, but i guess not.
I dont get it!
Nathan
Old Nov 24, 2003 | 06:58 PM
Whats weird is my girlfriends Jetta had the exact same problem superficially..but what it turned out being was some switch behind the brake pedal that allerted the computer it was fully depressed and would allow the driver to get out of park, it was a simple thing to fix. This may be dumb...but does anyone know if our cars have a similiar mechanism?
Nathan
Old Nov 24, 2003 | 07:08 PM
they have to
Old Nov 24, 2003 | 08:09 PM
missetti's Avatar
Yeah my Corvette does the same thing when it is cold. I found if I let the car warm up for about 10 min. it will release. Once it releashes, it doesn't do it again. Kevin
Old Nov 24, 2003 | 08:21 PM
Nathan
check this thread
http://web.camaross.com/forums/showt...hreadid=196715
Old Nov 24, 2003 | 10:20 PM
Sweetred95ta's Avatar
My car does the same thing, but it seems when I apply the e-brake before I put my car in park, it comes out easier. But mine gets so bad that it feels like I am going to rip the whole console out of the car before the shifter moves. It's strange.
Benji
Old Nov 25, 2003 | 12:46 PM
tufZ's Avatar
locked-in PARK
Hey guys, long time since I chimed in... My 95Z has the problem Every Winter during past 3 years. It only occurs during winter months. I tried oilin everything within that shifter area, but don't help. I have to use both thumbs to press that button. After warmup, the unit's fine. WTF.... of course there's none aftermarket shifters for our elect tranny, so I'm stuck. I'd really like someone to figure it out. My thought is to take apart the unit and drill a hole through the stalk. This would be parrallel to the floor, then stake a paperclip through the hole which would hold the button depressed at all times.!!! IT's THAT FRUSTRATING.
BPS
9
Mar 5, 2015 10:51 PM
737drivr
Feb 20, 2015 11:54 AM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
tds1213
Nov 27, 2014 12:55 PM
