Problems with CSR e/ waterpump
Old Aug 6, 2005 | 09:29 AM
1-bad-z28's Avatar
Did anybody have any problems with their CSR waterpump not fitting? I guess I will have to notch the old pump housing to allow it to slide down in there. Another thing too....does anybody have any wiring instructions? This thing only came with 2 stickers and no instructions.
Old Aug 6, 2005 | 10:30 AM
camaroKid223's Avatar
Re: Problems with CSR e/ waterpump
You have to notch the waterpump housing like you said, just dremal out a notch for each of those little ears on the pump. Its no biggie just be sure to get all the shavings out before you install it.
Old Aug 6, 2005 | 10:33 AM
ZMAN Z28's Avatar
One wire goes to ground and the other goes to a 12 volt source. I have my 12V source to a key on accessory.
ZMAN
Old Aug 6, 2005 | 06:37 PM
Robs97Z28's Avatar
I know this isn't the same pump, but it has some good info in it.
http://www.projecttransam.com/projects9.asp
thenewkid
Apr 12, 2015 07:42 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
