Problems after mods
Old Jul 22, 2003 | 10:53 AM
  #16
Green G0blin's Avatar
and about obd1 scanning.
i plug in my obd2 scanner, but it wont read th obd1 computer. says error on my scanner screen.
i think its cus its 2 different operations? OBD2 and OBD1?
should i reinstall my obd2 and try it that way? see what codes pop up?
Old Jul 22, 2003 | 10:55 AM
  #17
Jason
1996 formula
computer was programmed by madz28.com for my mods
i am running hooker long tube headers with true duals (x and dynomax bullets)
Old Jul 22, 2003 | 12:26 PM
  #18
96ZRDR's Avatar
I bet your running pig rich, pull out one of your plugs to verify.
Old Jul 22, 2003 | 12:33 PM
  #19
i did take out the plugs and some were wet but i switched them already.
am i still running rich? the comp was reprogrammed
Old Jul 22, 2003 | 12:41 PM
  #20
Newbie97's Avatar
Dude bad opti. I had the same problem when I switched to the hot cam on my Impala. It drove for a day and die, start up and die. I thought it was my MSD. I unhook it and it ran for two days. I then took it out on soom 6700 rpm shifts and that done it. Got home and turn the car off it wouldnt even start. Order an opti from Dal and fired it up when I got it ;no problems. Oh Dal has all Gm parts for Lt1 car for well under market price give him a call and tell him Travis sent you 1877 448 5451.
But before I done all that I had a new opti on and it would even start put the old one on and she fired right up. I even torn down to check the timing chain. What a mess I dont wont to remember now. Damn the Opti Spark. Some on the Impalassforum have changed their Lt1 over to the ls1 coilpacks. That is the best option but expensive. Forget about Dynaspark as well. WQay toooo high.
Old Jul 22, 2003 | 12:42 PM
  #21
96ZRDR's Avatar
Pull them again, and you will see that you are still running rich....!
Answer/do the following:
1.) Any codes? Which? You must get a data logger!!
2.) Get a spray bottle and spray your header primaries one by one, does one of the other seem cooler than the rest? Could be your opti.... if this is true. Mine was.
3.) Are your wires good, are they arcing (look at them at night).
Anything else, you would have to diagnose with a data logger.
Good Luck
Old Jul 22, 2003 | 01:04 PM
  #22
well yeah i wanted to pull the plugs and see for myself again.
the wires are not arching that i checked, i will need to re check to see if they are connected all the way and correct order.
i was told to check my fuel pressure? should be at 40-45 i think i was told
if i order the opti today, and i check the fuel pressure on my car and find out its the fuel pump, or wires, can i return the opti if its not opened?
i was thinking on buying a new opti, msd blaster coil and well if needed, new plugs
anything else?
Old Jul 22, 2003 | 02:16 PM
  #23
any more recommendations? before i waste more money?
Old Jul 22, 2003 | 02:26 PM
  #24
96ZRDR's Avatar
I guess if you want to take a stab at it, I would say opti or opti wire harness (check for corrosion), but for your monies' worth I would get a data logger. It is worth every penny.
Old Jul 22, 2003 | 02:27 PM
  #25
give me info on where to get a data logger? i am new to the lt1 scene
Old Jul 22, 2003 | 02:52 PM
  #26
96ZRDR's Avatar
I do not know what model year your car is, but on mine I use a laptop, and DATAMASTER (software) to download sensor information that is available for playback. This information is super valuable, and gives a first hand information of where to start looking.
The software is availabe "free" at TTS (do a search for the website), you will need a ALDL cable (avail. at AKMcables.com), (Obd1 or Obd2, do not know what your car is) and ofcourse a laptop or desktop if you can move around in it.
Do a search, and you will find extensive information.
Use ALDL, DATAMASTER, as your search terms.
Datamaster Trial version is free (30 free scans)
ALDL cable is about $90 from AKMcables.com
Later
Old Jul 22, 2003 | 02:54 PM
  #27
mine is a 1996 formula
so it would work the same way correct?
but i have obd1 computer but obd2 connector...since i did the obd1 conversion
Old Jul 22, 2003 | 02:58 PM
  #28
96ZRDR's Avatar
Hmmmm. I believe you will need an OBD2 cable for your car, if anything I would ask MADWOLF. He is a programming expert.
Old Jul 22, 2003 | 03:07 PM
  #29
and the programmer of my obd1 conversion as well
Old Jul 22, 2003 | 03:55 PM
  #30
25thAnnTA's Avatar
My buddies TA ran like crap down low, stumbled and such after same iinsatll. He adjusted the rockers too tight, should have only put .75 to 1 full turn past 0 lash, made the changes and it ran alot better.......just more thoughts. -good luck.
Noenav
Mar 1, 2019 07:38 AM
97ChameleonTA
Jun 4, 2015 08:19 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
