Problem With Underdrive Crank Pulley
Old May 10, 2004 | 05:56 PM
uscgreel's Avatar
ALRIGHT MY RIDE CAME WITH A UNDERDRIVE PULLEY ON THE CRANK BUT IT LOOKS LIKE A PIECE...MY PROBLEM IS MY BELT WORE OUT DO TO THE JUNK PULLEY AND I CANNOT FIND A REPLACEMENT THAT FITS. I WANT TO REPLACE THE PULLEY AND GET A HARMONIC BALANCED UNDERDRIVE PULLEY AND A OVERDRIVE ALTERNATOR PULLEY. (WHICH WOULD GIVE ME A BETTER CHARGE ON BATTERY AND EASIER STARTS, CORRECT?) IS IT WORTH SPENDING THE EXTRA DOUGH TO GET A HARMONIC BALANCED PULLEY. IT DOESNT HAVE ONE ON IT NOW AND I BELIEVE THATS WHAT HAS MADE MY CRANKSHAFT SEAL GO OUT. WHAT DO YOU GUYS GOT FOR ME?
1994 CAMARO Z-28
UNDERDRIVE PULLEY, MAF SCREEN, ACCEL COIL, CAT. REMOVED
Old May 10, 2004 | 06:12 PM
80TA's Avatar
I had an add on asp pulley on my 97 ta.I thought it added vibration .I plan on buying a harmonic balancer replacement type of pulley .Asp makes them but they are pricey and very hard to get.Still trying to get one.Might have to order from somewhere like asp themselves and just wait for it..could be months..
Old May 10, 2004 | 07:32 PM
MeanZ687's Avatar
is it bad for the car when at idle with it in drive the charge needle sits right above the red, but when you start driving it goes back up?
Old May 10, 2004 | 08:19 PM
80TA's Avatar
You can buy some overdrive pulleys to help with this depending on what make of underdrive you have..asp makes alternator overdrive pulleys.
HectorM52
Jun 23, 2016 08:42 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
QuickSilver02
Apr 7, 2015 11:12 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
