Problem with Throttle Body Bypass!
Old May 12, 2004 | 10:31 PM
Envok's Avatar
Hello,
Today , I did the throttle body bypass on my 1994 Camaro Z28. I took the 2 hoses off the throttle body and connected them using a bypass connector and clamped them. I had some trouble getting the hose off on the right side of the throttle body so I took off some hoses around it. The car being 10 years-ish old, an elbow tubing about a quarter inch tubing got all crumbly and partically tore in two places. When I started the car up it ran fine for a little while but after it heated up it bogged down ALOT on take off if I floored it . It bogged down to the point where it was barely moving . I searched and haven't found any other people that have had the same problem. What did I do to my Camaro!
Thanks,
Envok
Old May 12, 2004 | 10:33 PM
BadAssed93Z's Avatar
replace/repair that hose.
vacuum hoses are kind of an important thing on cars.
good luck.
Old May 13, 2004 | 06:13 AM
Mtrhds94Z's Avatar
Is it GM p/n 10105324 in this diagram[from shoebox' site]?:
http://shbox.com/1/1995_evap.jpg
If so thats about 5-7 bux to replace..
Old May 13, 2004 | 12:32 PM
You might also want to check the intake elbow, to make sure you didn't tear it, or roll the bottom edge under so it isn't sealed to the throttle body.
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
lt1-xjs
Jan 17, 2015 07:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
RedLineRev
Jan 23, 2003 03:51 PM
