problem starting
Old Sep 23, 2007 | 09:07 PM
raulz28's Avatar
From: 5 minutes from the warzone in mexico(south texas)
problem starting
Hey guys i hav 1994 camaro z28 and i hav no idea why da bitch doesnt start after it overheated pretty bad and dat problem has been fixed. It turns over, fuel pump is good, good fuel flow, and has spark but da bitch wont start i would really appreciate any help and thnx in advance.
Old Sep 23, 2007 | 09:34 PM
seawolf06's Avatar
If your head is warped, you could be losing compression maybe? That's the 3 things you need: spark, fuel and compression. You must be missing one somehow.
Old Sep 23, 2007 | 10:18 PM
raulz28's Avatar
alright thnx man ill make sure i check dat **** out, and can a blown head gasket cause it 2 lose compression?
Old Sep 23, 2007 | 10:58 PM
mrmint69's Avatar
How long was the car sitting for after it overheated. I had mine sit for a long time and the battery was low enough it would try to start but nothing. I was able to jump it and that fixed the problem. Its a stretch, but you are looking for a needle right now.
Old Sep 24, 2007 | 09:19 PM
raulz28's Avatar
um da car was sitting 4 about i would say 2 or 3 days. i would really appreciate any tips guys
Old Sep 26, 2007 | 05:56 AM
Guest47904's Avatar
Guest
Does it have injector pulses? Try squirting fuel in the intake and then crank it over.
karnykamaro
Feb 2, 2015 01:37 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
Britbilly
Jan 7, 2015 08:49 PM
