problem with rockers and retainers
Old Mar 21, 2004 | 02:57 PM
lt1camaroman93's Avatar
I was going to put my rockers on last nite and it seems that 5 of the valve stems dont stick out of the retainers high enough.. the rocker body is hitting the reatainer and not allowing the tip of the rocker to get the the valve stem. the rockers or comp cams pro mag's. can anyone give me some advice of what to do. one option i was told is to change locks and run a lash cap.
Old Mar 21, 2004 | 03:00 PM
FormulaLT-1's Avatar
what springs, shims, and retainers?
Old Mar 21, 2004 | 03:07 PM
i don't know part numbers, but it is all comp cams stuff. dual springs, titanium lock, and unkown locks. 11 of the vavle stems stick out plenty far.
Old Mar 21, 2004 | 05:04 PM
Appears to be material for "LT1 Tech"..... moving it there.
Old Mar 23, 2004 | 10:14 AM
ttt, I'm looking at the same problem RIGHT now, with K800's and titanium retainers.
Old Mar 23, 2004 | 11:55 AM
DR.ZED's Avatar
Re: problem with rockers and retainers
Originally posted by lt1camaroman93
I was going to put my rockers on last nite and it seems that 5 of the valve stems dont stick out of the retainers high enough.. the rocker body is hitting the reatainer and not allowing the tip of the rocker to get the the valve stem. the rockers or comp cams pro mag's. can anyone give me some advice of what to do. one option i was told is to change locks and run a last cap.
When you installed the caps on the studs that you adjust.... you're sure they're sitting inside the "cup" of the roller rocker shaft?
If you spin this shaft on the roller rocker you'll notice you have a flat side, and a machined side for the rocker stud to sit into. Take off the rocker and see what I mean.
Old Mar 23, 2004 | 01:44 PM
i dont even have to have the polly locks on to see this problem.. all i have to do it seat the back of the rocker on the pushrod and the body hits the retainer and the tip wont hit the valve.
Old Mar 23, 2004 | 04:30 PM
ok, I kinda solved mine, mine was really close, only a paper width apart, so I just did a little dremel work.
but here are some things to look for, do you have the right lenght pushrods, right shims, anything bent? any machine work not taken into consideration i.e. mill heads/deck block?
Old Mar 23, 2004 | 06:00 PM
pushrods are dead nuts on for the valves that the rockers acctualy make it to. I did the magic marker thing and it only wore the pater out dead center on the vavle. Now with the 5 valve being shorter wouldn't that maybe require a different pushrod length becasue the geometry is different? I am going to get 1 pushrod that is .200 long and see if that works, because i am already running .100 longs.
LeftoverChinese
Jan 14, 2024 03:03 PM
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
