problem with idle when driving in rain
Old Aug 6, 2009 | 05:08 PM
tricky69's Avatar
Hello all,
i have a 1994 Z all stock, have just replaced plugs, cap, rotor, and opti and when i drive in the rain the car starts to idle bad when i let off the gas but seems fine when I'm on the gas. it only does it when its raining or the roads are still wet. any ideas on what might be causing this?
Old Aug 6, 2009 | 06:48 PM
cusz28's Avatar
did it do this before you changed all this stuff, or you changed it because of it?
Old Aug 6, 2009 | 06:50 PM
cusz28's Avatar
if you just changed all this because of the idle problem, i might check and make sure your not getting water in your engine. i would also check the opti vent tubes. i think that year had them hooked to vaccum.
Old Aug 6, 2009 | 09:40 PM
evilundisguised's Avatar
Did you also replace plug wires? Old wires and moisture/humidity can cause arcing & misfires.
Old Aug 6, 2009 | 11:15 PM
94 Opti is unvented = no vacuum or air supply lines.
Old Aug 7, 2009 | 02:17 PM
tricky69's Avatar
didn't do work myself but im pretty sure that the wires were not replaced, have also noticed that i keep getting a slight knocking and pinging when i press slighty down on the gas almost like i put crapy fuel in but i always put 93 in it, so im not sure if wires would cause the problem with the moisture and the knocking and pinging or not.
Old Aug 7, 2009 | 05:19 PM
You may have cross-firing on the wires, which might produce knock. The amount of timing error on a cross-fire might exceed the ability of the PCM to pull timing in response to the knock sensor.
Open the hood at night, in a dark area. Look for arcing on the wires and around the coil and distributor. If you don't see arcing, spray a small mist of water on the wires and see if that causes arcing. Don't spray anything on the distributor.
Noenav
Mar 1, 2019 07:38 AM
Gtpguy
Jan 26, 2015 04:50 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Britbilly
Jan 7, 2015 08:49 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
