Problem hooking up datamaster
Old Aug 1, 2010 | 08:19 PM
EDS Z28's Avatar
Unhappy Problem hooking up datamaster
I haven't used datamaster on my car in about 10 years. Back then I had a laptop which had a standard serial port, I never had a problem with the connection from the ALDL to the laptop. Now, with a newer laptop and USB connection, I ordered a new usb cable from AKM. It came with a replacement portion of the cable which enables use to a USB port, and it came with a CD disk with the drivers on it. Well, it still doesn't work, it gives me a datamaster error code #1, ALDL connection is good but no PCM detected. What the hell does that mean and how do I fix this??
Thanks Ed
Old Aug 1, 2010 | 08:31 PM
Did you check with Andrew at AKM?
Old Aug 1, 2010 | 09:36 PM
EDS Z28's Avatar
Well I toyed around with it for awhile. I ended up resetting the COM ports on the laptop and on datamaster so they matched. It works now!
mr28
Apr 20, 2016 05:44 PM
Injuneer
Dec 15, 2014 09:36 AM
mr28
Nov 23, 2014 11:11 AM
Teal94V-6
Aug 31, 2002 09:21 PM
Camaro90RS
Jul 23, 2002 07:57 AM
