Problem with Caliper
Old Oct 30, 2004 | 01:30 PM
MikeStank's Avatar
I've been having brake problems recently and decided it was time to work on them, so i'm in the process of doing pads and rotors because they are grooved. I can't free up the one floating caliper mount. I've tried everything, penetrating fluid, heat, and beating the crap out of it. Well the rod is bent now, but its still stuck. Any suggestions??
Old Oct 30, 2004 | 03:23 PM
Bryan Smith's Avatar
Re: Problem with Caliper
Is the floating rod unscrewed just wont come out? Or are the threads locked to the caliper mounting bracket. I know with a few of mine Ive had to use a tap and just beat on it for a few with a hammer.
Old Oct 30, 2004 | 03:44 PM
MikeStank's Avatar
Yes, its unscrewed, i actually have the bracket off the car, just can't get the stupid rod out. I already got a replacement rod.
I am going to put the bracket in the freezer, without my mother seeing, and i'll try to heat the bracket without the pin, hopefully i can get it out then.
Old Oct 30, 2004 | 06:24 PM
MikeStank's Avatar
I'll be ordeirning a new bracket Snapped off clean at the hole
Old Oct 30, 2004 | 06:52 PM
TQdrivenws6's Avatar
Why don't you use a press?
Old Oct 30, 2004 | 07:09 PM
MikeStank's Avatar
no way to press it out, its solid on the other end
Old Oct 30, 2004 | 07:10 PM
There is always a way. What about a close fitting dowel and oil? That usually works quite well.
Old Oct 31, 2004 | 03:31 AM
oh well its not too expensive.
carguy0119
Apr 11, 2016 11:11 PM
Fastbird93
Apr 9, 2016 07:01 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
Z-rated97
Mar 29, 2015 11:17 PM
FirebirdGT
Dec 13, 2014 10:25 PM
