Problem Bigger Than First Thought
Old Jan 2, 2004 | 02:38 PM
HighFlyinZ's Avatar
Heres The story:
My roommate and I were driving down the high way one night when all of a sudden I lost power in all gears. and had a few sparks fly from under the car, The car would not accelerate at all. So I pulled over and turned the car over. Looked under the car and the first inch or so before the CAT was glowing read. We gave it a few minutes - Started the car back up and got about another 2 miles or so before I got the same thing again, with the exceptions of sparks. This time it wouldnt start back up. I finally got around to cutting the CAT off and still got nothing. We assumed it was melted and wouldnt start. Well That didnt help any either.
About two weeks prior I had put bad gas into the car - and had a ton of trouble figuring that problem out too. We changed the injectors for some my buddy had and the problem went away and drove fine. I dont know if that had anything to do with it not starting now but I figured Id mention it.
Any Ideas what to do/try now?
Old Jan 2, 2004 | 04:07 PM
RMC's Avatar
RMC
Pull the easiest spark plug you can get to and report on it's condition/color. That may confirm if the engine was running too lean to cause the glowing.
Old Jan 2, 2004 | 04:51 PM
HighFlyinZ's Avatar
Its pretty cold out - and Im in dorms so there isnt a place to pull the car to stay warm so I'll check out the plugs tommorow. The injectors we put in the car are temporary and were pulled out of a Impala - Would that cause the car to run lean? Before the bad gas incident the car ran fine so I dont know what else would have caused it to run lean.
Old Jan 2, 2004 | 11:50 PM
HighFlyinZ's Avatar
Just trying to get Ideas before tommorow when I get a chance to pull a plug.
Old Jan 2, 2004 | 11:53 PM
bunker's Avatar
When you turn it over (try starting) does it go faster then ussual or slow? if its really fast you might have something to worry about, otherwise I would keep looking at small things.
Old Jan 2, 2004 | 11:56 PM
HighFlyinZ's Avatar
I dont know - Didnt really notice. Excuse my ignorance but what would be the worry Im in for if it was turning over faster than usuaul?
Old Jan 3, 2004 | 12:00 AM
HesterZ28's Avatar
If it was turning over faster then usual it means you lost some compression
Old Jan 3, 2004 | 12:11 AM
HighFlyinZ's Avatar
Ouch - Ok, Tommorow after work I'll check it out. Could those Impala injectors have caused me to run lean?
Old Jan 3, 2004 | 07:35 PM
HighFlyinZ's Avatar
I pulled one of the plugs and took some pictures. Tommorow I will check for spark but take a look and let me know if you think anything.
Ugly Plugs
Old Jan 3, 2004 | 09:55 PM
HighFlyinZ's Avatar
Im pretty ignorant as far as car's go - Need some help!
Old Jan 4, 2004 | 12:39 AM
BeaversTA's Avatar
What size are the injectors you put in? If they are larger than stock you should have been running very rich or if smaller to lean.
Just a thought.
Old Jan 4, 2004 | 01:09 AM
HighFlyinZ's Avatar
They came out of an Impala - What # are Impala Injectors/ and what # are Stock Camaro?
Old Jan 4, 2004 | 01:54 AM
SVT Killer LV's Avatar
Hey Im in Henderson.. I can stop by with some injectors and take a look see at your car. I'm pretty well respected locally with the LT1's
Old Jan 4, 2004 | 01:56 AM
those plugs ARE DONE FOR.... give me call
810-4594
Old Jan 4, 2004 | 01:57 AM
wouldn't a rich condition cause the cat to glow becuase of the elevated temps etc....
