Pro mags hitting rocker studs
Old Jul 5, 2012 | 11:36 AM
  #31
2QUIK6's Avatar
Re: Pro mags hitting rocker studs
My small base circle lpe cam was very noticeably smaller compared to the stocker and the previous comp cam, I'm betting it was quit a bit more than .1 of an inch. I had took some pics and measurement at one point because I did not order a small base circle cam. I'll see if I can dig up where I wrote down or maybe even posted the measurements.
Some one stated earlier that is did it matter if they had guide plates or not, but the thickness of the guide plate would push the top of the stud where his rocker is hitting up by an additional .1 of an inch or so due to the thickness while the overall rocker geometry should not change. Stud to be used with guide plates would have a little bit longer threads, never noticed if the rocker mount portion of the stud at the base is any different for NSA vs SA rockers.
Old Jul 8, 2012 | 03:51 PM
  #32
Jay7199's Avatar
I got some new pushrods, will update after they are installed.
Old Jul 10, 2012 | 10:12 PM
  #33
2QUIK6's Avatar
Finally found the measurements where I posted them, the stock cam is 1 1/8" base and the LPE was 7/8", difference of a 1/4" in base circle. I also had an LE1.5 cam at one point that was never used and it was 1.0" base circle, so there could be a .25" just in base circle difference depending on cam grind.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
Mar 13, 2016 03:39 PM
KamikaZ28
May 28, 2015 12:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
alphaauto
Jan 23, 2015 07:42 AM
