Pro Magnum 1.6RR's
Old Aug 12, 2003 | 04:55 AM
BigBlue95Z's Avatar
Pro Magnum 1.6RR's
I've got a chance to get some of these REALLY CHEAP and was wondering if you have to change the valve springs out when you do the RR. I'm kinda tight on $$$ right now BUT plan on cam/head port in the next 6mo or so. So the springs will def get swaped then. Let me know!! Thanks a bunch!!!!
Jason
Old Aug 12, 2003 | 09:09 AM
LWillmann's Avatar
If you're getting 1.6 ration roller rockers then you should change the springs at the same time. I don't think the stock springs can take the lift.
Old Aug 12, 2003 | 09:14 AM
Severous01's Avatar
if you have the option to get cheap rr's now, then get them and put them on later when you get new springs. i dont plan on doing it all at once, but when i get the spare change, i plan on buying all the components for killer heads and piecing them together later.
Old Aug 12, 2003 | 09:01 PM
Bud M's Avatar
I wouldn't run 1.6s on the stock springs. You can get LT4 springs/retainers/keepers pretty cheap.
Old Aug 12, 2003 | 09:12 PM
jim88iroc305's Avatar
Cool
I think you have to change the springs. Others will think different but the stock springs are for 1.5 and that is it.
13qtr
Oct 28, 2016 08:11 PM
Quickss96
Jan 29, 2016 05:56 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
