Pro 5.0 install
Old Apr 3, 2003 | 11:22 PM
CDN WS6's Avatar
Pro 5.0 install
Hey there,
I'm getting ready to install my Pro5.0 shifter. I will be using the install guide from project trans am. Are there any other sites that may have better info? I know this is a simple mod but I want to do it right and it's basically my first time modding my car. So far I have thread locker and GM RTV sealent(free, my brother's a GM mechanic!). Do I need anything else?
Thanks for helping this newbie!
Tyler
Old Apr 4, 2003 | 12:08 AM
x7x7's Avatar
Here are pics from my pro 5.0 install:
http://members.shaw.ca/nrfarley/pics/Pro5.0%20install/
I would recommend that you use thread locker on the bolts that attach the stick to the shifter assembly (I had mine loosen a couple times already). And, it seems most people like the Pro 5.0 shifter best with about 1 inch or so cut off the stick. I took about an inch of mine and love it.
One other complaint people have is that they transfer more noise into the cabin especially with a poly trans. mount. I used a big thick square mouse pad trimed with a hole in the middle to slip over the shifter ounce it was all toether again and that took away a lot of the noise.
Old Apr 4, 2003 | 01:29 AM
Ernster500's Avatar
Re: Pro 5.0 install
Hey Tyler,
Sounds like you have everything you need. You might want to put that thread locker on the shift-stop bolts in addition to the shifter handle. One of those bolts backed down on me a while back and caused my shifter to jump out of first when I was starting out. Freaked me out!
Other than that, the install is pretty straight forward.
The Pro 5.0 was the second mod I did (the first was !CAGS ).
You are going to LOVE your new shifter!
Have fun!
E
Old Apr 4, 2003 | 03:55 PM
mineralwater's Avatar
Re: Re: Pro 5.0 install
same here.
I cut about 3/4" off the top with a dremel, and I LOVE it! I put the stock shifter back on just for fun, and it was a WORLD of difference. I just cannot stand driving a stock-shifter car anymore, the throws are just so long and loose..
Old Apr 5, 2003 | 05:03 AM
Thomash's Avatar
Even with lock-tite I had trouble with the two small bolts that hold the shift handle to the base. I wrapped two hose clamps around them to help hold every everything together.
Old Apr 5, 2003 | 09:08 AM
notstock4long's Avatar
Sounds like you have everything under control. The hardest thing for me to do was figure out how to get the ebrake to com straight up. Other than that, you might want to get some really thin paper gasket material, and make a gasket just like the box the shifter connects to. I didn't do that the first time, but I went back and did it and it really helped with road noise. Only cost $3 from ACE hardware, so it was worth it.
Old Apr 5, 2003 | 12:34 PM
Lions3's Avatar
Tyler, I've already offered to come help you out
It's a piece of cake, don't worry about it.
Old Apr 14, 2003 | 08:35 PM
cridom's Avatar
im getting mine tomorrow
are thread locker the same as those ring cut in the middle a bit twisted?
if not where can i get it and how does it look?
Old Apr 14, 2003 | 08:56 PM
ChewyChevy's Avatar
Hey all,
Thread Locker (Lock-tite) is a red fluid that locks the bolt onto place and prevents it from comming loose (forever supposedly). This helps as the Pro5.0 bolts that hold the shifter shaft in place come loose due to tranny vibration comming up to the Shifter. Good luck
Alex
Old Apr 14, 2003 | 11:14 PM
cridom's Avatar
can i get it at advance auto parts?????
thanks
Hoodshaker
Aug 27, 2002 02:32 PM
x7x7
Aug 15, 2002 06:49 PM
jim88iroc305
Aug 13, 2002 09:24 PM
Krab
Aug 5, 2002 12:08 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
