pro 5.0 comming in the mail on tuesday!!!!!!!help!!
Old Apr 12, 2003 | 10:29 PM
cridom's Avatar
what should i buy for the installation?
any tips for noise reduction?
also with what can i cut the stick???
i have a grinder is that work?
Old Apr 12, 2003 | 11:08 PM
norcalstreet's Avatar
You should buy some RTV to seal the shifter on the transmission, use a dremel or just a saw to cut off about 1.5 inches of thread. You could buy some gasket paper and make your own gasket but when I did it I found it to be messy and it didn't reduce the sounds as much as I hope so I took the gasket off and used just RTV.
Old Apr 12, 2003 | 11:26 PM
sandmanljs's Avatar
Deffentally dont forget the RTV. When you take the old RTV off you might want to put a shop cloth in the tranny so it dosnt get in there.
I used a cut-off wheel to cut mine, a dremel or hack saw will work, just require more work.
Putting some lock tight(a thread locker) on the bolts that hold the stick to the shifter. Putting some lock tight(not the red kind) on the bolts that hold the shifter to the tranny.
Good luck, its really not that hard. Its a huge improvment over stock. Have fun.
Old Apr 13, 2003 | 07:57 AM
Laymaster's Avatar
I made a webpage about how to install a pro 5.0, it's on my site in my sig....
ChrisFrez
Jan 4, 2015 08:43 AM
ChrisFrez
Dec 28, 2014 02:25 PM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
Krab
Aug 5, 2002 12:08 AM
