Previous owner disables SES light..How can I get it back?
Old Dec 19, 2006 | 12:03 PM
Jazsun's Avatar
So today I found out my cars were hollowed out. which explains why when I got emissions tested it threw 2 codes for the cats. So that problem is solved. Now I have the problem of there being no SES light at all. I am almost positive that the previous owner cut or unhooked it in someway so prevent buyers from seeing it since it would have been on if the car had no cats.
I tried something I searched and found in another thread of unplugging the blue connector to the pcm and grounding the brown/white wire to see if it would come on. And it didn't so its definitely a circuit issue.
I looked in my hayes book and it had a diagram but its hard to follow where exactly in the car it goes. Where should I check is there some kind of connector somewhere which I could check?
Old Dec 19, 2006 | 12:35 PM
bingo's Avatar
Have you checked the bulb?
Old Dec 19, 2006 | 12:38 PM
bingo's Avatar
Old Dec 19, 2006 | 03:03 PM
Jazsun's Avatar
PRoblem fixed by mechanic. Thanks.
Old Dec 19, 2006 | 03:11 PM
RE AND CHERYL's Avatar
What was it?
Old Dec 19, 2006 | 03:22 PM
Jazsun's Avatar
Originally Posted by RE AND CHERYL
What was it?
Dunno Im going to pick it up after work, I'll ask then. Meanwhile if you could help w/ my air injection problem (stupid emissions) I posted it in LT1 tech as well.
ModdedNerd
Jan 29, 2015 07:23 PM
rjc1629
Jan 27, 2015 10:46 AM
cmdeshon
Dec 27, 2014 10:06 AM
fpete1992
Dec 11, 2014 03:51 PM
