$4-5K to spend on engine/upgrade
Old Dec 19, 2006 | 03:59 AM
ndnkyd's Avatar
Hey, guys, i've blown my '93 LT1, sister ran car hot, still starts, but runs horrible, so i know its pretty bad. I have $4-5K to spend on fixing her up! Is there chance for a performance upgrade on the blown motor? Should i drop another motor? I would like to get the most bang for the buck, i welcome any and all suggestions. Remember, more power, the better. Thanks.
Old Dec 19, 2006 | 06:28 AM
SS RRR's Avatar
i'd do a stock rebuild on the block w/ aftermarket heads/cam. you should be able to barely squeak by w/ that kind of money as long as you do the work yourself.
Old Dec 19, 2006 | 06:50 AM
streetheatz28's Avatar
It really depends on what damage was done to the block. If the block itself is ok you will be fine. You can buy a forged rebuild kit from summit for under $700. You can get a eagle or scat cast crank for under $400 get a set of I-beam rods from eagle for under $300. Top it off with LE2 heads/cam for under $1,500. Buy odds and end parts like headers, 58mm tb etc. with rest of money. That all adds up to $2,900 you will have over 1,500 for other stuff and you might want to invest a little of it in your transmission.
If you can't build yourself the shop should be able to rebuild it back to stock specs port the stock heads and install a decent cam for around 4k.
Old Dec 19, 2006 | 11:16 AM
2000GTP's Avatar
Thats a pretty nice budget to work with. I would call some shops and get some quotes on a bottom end rebuild as the prices can vary. As for the top end, a budget heads/cam kit from Lloyd will really wake the car up: www.eportworks.com Another idea would be to buy a completely built up shortblock from www.victoryracingengines.com
Old Dec 19, 2006 | 05:28 PM
gsxowner's Avatar
stroke it to a 383 and then add some forged rods and pistons, port the stock heads, more radical cam, that will be a good budget setup, then a great setup to add a blower or spray to when you want more.
Old Dec 19, 2006 | 07:24 PM
SS RRR's Avatar
with the kind of money mentioned a 383 short block would eat that all up.
Old Dec 19, 2006 | 09:14 PM
CamaroRacing12's Avatar
buy a beater, save up and buy a 383 stroker setup from victoryracingengines.com then throw in LE2 heads and a GM847 cam and send ur tranny to CPT for the pro race rebuild and add a 3200 TC, then buy a 12 bolt rear end with some 4.10's...... u'll be running 11's add a shot of nitrous and break into the 10's........hehe thats my plan b4 i get old haha
Old Dec 20, 2006 | 05:22 AM
96 TA's Avatar
http://www.golenengineservice.com/html/lt1_lt4.html
I have been looking at these golen long blocks lately. They also offer short blocks, 355's and 383's starting at $2600. They appear to be really good quality, might be something for you to look into.
RX Speed Works
Aug 11, 2015 11:16 PM
whitehooptie
Aug 10, 2015 07:02 AM
Devinfoote87
Jul 30, 2015 09:54 AM
colts0455
Jul 28, 2015 11:28 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
