premature spark plug failure
Old Jul 29, 2007 | 01:20 PM
bmwmcars's Avatar
Angry premature spark plug failure
working on my friends z28 today, again. 95 z28, motor is an lt1, lt4 heads, lt4 intake, 383, 230/236 cam, ltcc, and a dyno tune, wot 12.5:1 afr, no knock.
for some reason, the car is eating spark plugs. they fail after as little as 20 miles. when one or more fails, the car has a noticeable stumble and chugs really bad.
replacing the plugs *always* resolves the problem for a short period of time. taking ohm readings of the plugs finds 1 or more with very inconsistent readings from the others.
any thoughts on what this could be? we have tried ngk, autolite, ac delco plugs, all with the same results. we are really bored of doing plug changes on this thing.
should we try a colder heat range? could it be under hood heat? totally lost.
thanks for the help.
Old Jul 30, 2007 | 09:25 AM
OBE1 95Z28's Avatar
What is the failure mode of the plugs (missing electrode, fouled)?
Old Jul 30, 2007 | 09:34 AM
bmwmcars's Avatar
neither. they look perfect when pulled out. but if you resistance test them, they are all over the place and usually over 10kohms.
Old Jul 30, 2007 | 10:13 PM
JP95ZM6's Avatar
Is that checking wire end to center electrode, or to ground? Any signs of arc tracks along the outside of the ceramic, from the boot to the metal body?
Old Jul 31, 2007 | 06:21 PM
bmwmcars's Avatar
its checking from the center electrode to the stud where the wire connects.
no signs of arc tracks, no cracks in the ceramic, nothing.
Old Jul 31, 2007 | 09:45 PM
JP95ZM6's Avatar
Hmm. I frankly don't know what plug resistance should be, as I always test them by making them spark, and looking. Even searched for a spec.
Old Jul 31, 2007 | 09:55 PM
Kevin97ss's Avatar
I've seen some plugs do this if they are overtightend. Also take the rubber out of the spark plug socket if using one or just use a regular socket. The rubber can cause side loading of the porcelin. Can't think of any engine issues that would cause resistance failure so soon.
Old Aug 1, 2007 | 10:05 AM
arcticz28the383's Avatar
Also make sure your not cracking the plugs when you install them, this can make them arc to the engine and cause a miss. Dropping them can cause this also.
Old Aug 1, 2007 | 10:55 AM
bmwmcars's Avatar
of course a few have been cracked at install, but i always pull them out and replace them. if i drop one, it gets junked as well.
tks for the infos.
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
Chet1185
Apr 26, 2015 04:07 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
