Pre-Deployment final resoulution thread!!!
Old Apr 20, 2010 | 09:20 PM
  #16
dangalla's Avatar
the valvetrain is not an area you want to skimp
you should be able to get by with a set a self aligning rockers, which will keep the cost down because you wont require chromolly pushrods or guideplates.
comp is a good brand, that is what i run., you would be looking at a set of
3/8th 1.6 SA pro mags $341 from thunder part # 63-1318-16
or
3/8 1.6 SA magnum $183 from thunder part # 63-1418-16
http://www.thunderracing.com/catalog...vid=4&pcid=108
3/8 studs $21 part #63-4500-16
and
you need locking nuts
http://www.thunderracing.com/catalog...vid=4&pcid=221
Old Apr 20, 2010 | 09:25 PM
  #17
dangalla's Avatar
this is a link to the comp poly locks, they are cheaper than the arp units, which seams like it is becoming a factor for you
http://www.summitracing.com/parts/CCA-4601-16/
you will only save a dollar or two buying the rest of the parts from summit, and thunder helps to support our community, so i try to recommend that people buy parts from them any time possible. and they have great customer service. i have dealt with them personally many times.,, shipping is fast and order was always accurate
Old Apr 20, 2010 | 10:09 PM
  #18
z28beast's Avatar
also im taking my heads in this week for a milling and they said they will do a 4 angle grind and mill the heads for 225...sound rite? and when i was painting my block i got a little bit of paint over spray on the head mounting surface...what do you guys recommend to clean up the head surface before i re install my heads...last ?? do i have to use a dremel and clean up the coolant passage holes in the block? if so how do i remove the shavings from inside the block if i do
Henson071
Dec 30, 2015 09:55 PM
97SSdude
Aug 21, 2015 09:36 AM
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
Bxlt1
Jul 18, 2015 02:48 PM
