power wire
Old Jun 18, 2009 | 11:51 PM
94 355 lt1's Avatar
power wire
I'm rebuilding my lt1 and the car started once but now it wont start. I reallized the power wire is hot and smoke comes form the starter area when I try to start it. I bought a new starter and its still doing it. Any Ideas on what might be causing it?
Old Jun 18, 2009 | 11:57 PM
nd4spd200's Avatar
check all your wireing could be a bad ground
Old Jun 19, 2009 | 12:50 AM
94 355 lt1's Avatar
Does the ground wire that runs with the power wire from the battery bolt up to the block or the motormount
Old Jun 19, 2009 | 06:27 AM
nd4spd200's Avatar
bolts to block i think
Old Jun 19, 2009 | 08:34 AM
http://shbox.com/1/battery_cable_ground.jpg
Old Jun 19, 2009 | 10:50 PM
94 355 lt1's Avatar
Does anyone have any other ideas on what might be wrong
Old Jun 20, 2009 | 10:34 AM
94 355 lt1's Avatar
I was wondering where the long ground wire would go, that runs down the harness with the three that ground off to the coil. My car is a 94 if that matters because I caint find that wire on any of the diagram
Old Jun 21, 2009 | 12:51 AM
94 355 lt1's Avatar
any help would be very appreciated
Old Jun 21, 2009 | 12:57 AM
tonyv's Avatar
mine did the same thing when i rebuilt my engine, and theres a small wire that i took off and i didnt remember where it went, and i hooked it too the starter, and she did the same thing, but i put it on my block and it went away hope this helps
Old Jun 21, 2009 | 01:13 PM
94 355 lt1's Avatar
Thanks for the help but I already have that one on the block
Old Jun 23, 2009 | 11:39 PM
94 355 lt1's Avatar
Does anyone have anyother ideas on why it's doin this and any info on that long wire that runs with the three that run to the ign. coil
Old Jun 24, 2009 | 06:17 AM
The only long wire that is bundled with the coil wiring is for the temp sensor in the head. The wire is green.
http://shbox.com/1/harness7.jpg
Old Jun 24, 2009 | 07:53 AM
lr383's Avatar
Check to see if your main hot cable is contacting the starter or header .My is a 94 I have two wires that go to the starter one main hot cable and a purple wire from ing a small black wire for pcm ground and knock s wire. Could be hot is grounding out some place coming down from the bat .
$hawn
Aug 17, 2002 04:37 PM
rs91
Aug 13, 2002 12:09 PM
kandied91z
Aug 6, 2002 01:18 AM
zman0069
Aug 2, 2002 02:09 AM
sleeperZ96BT
Jul 24, 2002 11:28 AM
