The power of a tune up
Old Dec 11, 2003 | 07:51 PM
Zerosheaven's Avatar
Just changed my plugs to ngk tr6s and some MSD wires.
before i did this i would have a realy bad stumble at low rpms, and it would sometimes miss at higher RPMS, especialy while cruzin at 5-10 mph zones, my car would lunge forward and back, like i was a rookie stick driver, after the change, i can cruz at 3 mph as smooth as butter. i also feel a little smoother while smashing the throddle.
point of the thread, is dont forget about the little stuff, it can make a big diffrence in the long run.
Old Dec 11, 2003 | 11:29 PM
atljar's Avatar
Very true, not to mention LT1s for whatever reason are super sensitive to ignition problems.
Old Dec 12, 2003 | 01:56 AM
CamaroSS30thAnn's Avatar
true true very true i know alot about Lt1 and their ignition problems if u know what i mean
Old Dec 14, 2003 | 08:58 PM
joecool72's Avatar
How difficult of a job is it on the LT1? I'm planning a spark plug change sometime soon, myself, and would like to know how it all went for you.
Old Dec 14, 2003 | 09:01 PM
96M6's Avatar
Re: The power of a tune up
Are does the stock plugs?
Old Dec 14, 2003 | 09:03 PM
JoeliusZ28's Avatar
About as hard as it gets
Old Dec 14, 2003 | 09:21 PM
revtime's Avatar
First time I changed plugs and wires on my car it was stock with everything on it.
It took me 2 days.
Now I have LTs and AC delete and no emissions and I can change the plugs in about 30 minutes taking my time.
Old Dec 14, 2003 | 10:23 PM
notstock4long's Avatar
Re: Re: The power of a tune up
Old Dec 14, 2003 | 11:16 PM
RickS's Avatar
damn right!, when i bought my car it ran like crap (15.03@86.7mph)
since i changed the plugs, and wires it ran a 14.00 @95, and i missed my gear, i was traping at 101mph usualy, so i think it would have done a below 13.9, since then i have been bringing it up to tune, and it runs much better
i remember when it would sputter from 3.5k-5.9k rpm
it was like i was hitting a rev limiter at 4. it wouldnt rev any higher than 4k... now its doin much better
Old Dec 14, 2003 | 11:20 PM
spoogen622's Avatar
Old Dec 15, 2003 | 01:29 AM
Unique07's Avatar
>> the little stuff...?
Nice point...I wish more people would listen.
I imagine few people here can claim to be familar with the phrase 'Preventative maintenance' - The idea of replacing the part at a set interval, assuring that it _never_ gets a chance to fail, escapes the majority of car owners. Reading the last 20 pages of your owner's manual works wonders...but I digress...
I'm glad you found the root of your problem. It's satifying to know you've finally traced down something that's been bugging you like an unscratched itch
Old Dec 15, 2003 | 02:06 AM
S.J.S.'s Avatar
Just make sure you do most of it from the bottom. If worse comes to worse remove the Y-pipe. Took me like an hour the first time.
Old Dec 15, 2003 | 04:23 AM
easiest way to do is , is remove the alternator, and put it on ramps, took me about 1.5 days to do it and it was my first time, would have taken me less but i had work.
i used the ngk tr6s, these are not the stock replacment, rather a colder plug for nitrous which i am getting very soon stock plug is the tr55
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
InfernalVortex
Jan 17, 2015 09:35 AM
XtremeLt1
Sep 13, 2002 08:50 PM
