Power Steering tank ?
Hey, I'm putting a LT1 into a 3rd gen T/A and need to know the plumbing on the power steering tank. I know the larger hole on the bottom goes to the return line but what about the smaller one ?.............Thanks
ok, now i'm feeling really retarded. looking at my 3rd gen steering gear box there are (2) open fitting holes (1) is 18mm(return) and the other is 16mm(pressure), 16mm connects to the pump,18mm goes to the bottom of the resisvoir,but there is still a open nipple on the resisvoir what hooks to it ? wrong resisvoir maybe ?
Look at this diagram. Item 11 is the fat hose off the bottom of the reservoir. Maybe this will help you to be able to adapt it to your car.
Originally posted by 87 LT1 T/A
So there are 2 connections on the pump itself ? I did not see that nipple on # 11 on my pump, just the opening that seemed like the main pressure hose opening.....
carguyshu
Jan 22, 2017 11:19 AM
stockssn2o
May 25, 2015 08:54 AM
mspennyhughes
Mar 1, 2015 03:50 PM
SMO Q
Feb 11, 2015 07:13 AM
