Power Steering pump fittings
I have installed a LT4 in my 69 camaro and now working on power steering lines. I have the fittings for the high pressure side of the pump to the gear. My question is the bigger line entering the pump (from the reservoir). There's a tube coming out which is where I assume in the stock Corvette/Camaro applications a rubber line slips over with a clamp to hold it. I don't believe a -10 hose will slip over this tube. Can this tube be removed from the pump? If so, how? I would like to convert this port to a AN fitting to run a -10 line.
Thanks for any input.
Kevin
Kevin
SMO Q
Feb 11, 2015 07:13 AM
ro2207
Dec 4, 2014 06:18 PM
