Power steering help...
Old May 22, 2004 | 09:06 PM
96ta(nick)'s Avatar
Does a failing power steering pump bleed off fluid? I am losing fluid for some reason and it is not the hoses... And how hard are they to change?
Old May 22, 2004 | 09:18 PM
stereomandan's Avatar
The pump shouldn't bleed off fluid, even if it's bad.(normally, the pump will get very loud if it is bad and give a whining sound) I would check for leaks at the hose interfaces and the pump drive shaft seal, and the steering gear boots on the ends and the steering gear input shaft.
I'm guessing that the fluid is leaking from somewhere.
Dan
Old May 22, 2004 | 09:19 PM
96ta(nick)'s Avatar
ok thanks
Old May 26, 2004 | 04:14 PM
96ta(nick)'s Avatar
is there any way i can short belt it to bypass the pump for now? if so what size belt? and how do i route it?
Old May 26, 2004 | 05:23 PM
drewstealth's Avatar
I'm not sure where mine leaks from but it shoots fluid all over the front of my engine bay.
Old May 26, 2004 | 05:31 PM
Dave Feerst's Avatar
leaking fluid could be in the boots.
mspennyhughes
Mar 1, 2015 03:50 PM
