Power Shifting?
Old Apr 3, 2004 | 09:36 PM
z28poweredlt1's Avatar
Power Shifting?
what exactly is power shifting? and can it damage anything?
Old Apr 3, 2004 | 09:50 PM
95Z28ConvertCam's Avatar
its when you shift into the next gear without letting your foot off the gas and Im not sure if it can damage anything I used to do it all the time in a 89 RS I used to have and I never had a prob but yeah never no
Old Apr 3, 2004 | 09:54 PM
RedHottG2's Avatar
Power shifting is shifting the car through the gears w/the gas pedal always on the floor. This is done mostly at the track for lower ETs. This is not recommended for street driving because doing so over and over will cause drivetrain and trans. probs. At the track, if you are not a regular runner I would say go for it. If you go alot and run your car, I would stay away for it, unless you you are REALLY wanting to beat a best time you had in the past. But eventually it will cause probs. for your car.
Old Apr 3, 2004 | 10:40 PM
Dave88LX's Avatar
It's the only way to shift.
Old Apr 3, 2004 | 10:44 PM
RedHottG2's Avatar
Old Apr 3, 2004 | 10:47 PM
CamaroSS30thAnn's Avatar
isnt there two ways to powershift .....ie shifting without letting ur foot of the brake and not touching the clutch or very little?
Old Apr 3, 2004 | 10:51 PM
HardcoreRM125's Avatar
Think of it this way ...
Would you violently REV THE **** out of your engine in Nuetral and bounce it off the REV limiter, then MURDER the clutch by holding the throttle pinned while you let it out ?
Its REALLY hard on the car. It's also REALLY fun . Dont make it a habit though.
Old Apr 3, 2004 | 10:55 PM
my94blackz's Avatar
Umm if you dont shift fast enuff to get it off the limiter between shifts wow i bet you lose every race. If shifted fast enuff it wont stay in the red long.
Old Apr 3, 2004 | 10:57 PM
Dave88LX's Avatar
Rookie
Old Apr 4, 2004 | 12:08 AM
RedHottG2's Avatar
umm I think what you might be talking about is known as "double cluthing". This is done to stop alot of accessive spin off the line.
The second part is merly shifting without raising the gas pedal. This must be done knowing what RPM you will be at whaen the clutch is engaged and let out so you don't bounce the rev. limiter (or not if you have your programming set to no rev point). But I would always set a rev pointwithin reason. I know people who deleate there rev limiter in programing and that's vey dangerous if they miss a gear. High RPM already and no rev limit = BOOM (new motor)
Old Apr 4, 2004 | 12:24 AM
95_LT1_6SPD's Avatar
wow, so many people have a skewed view on what double clutching is.
Double clutching is for downshifts, and incase you dont know how to do it, it goes a little something like this.
Engage clutch
Shift into neutral
Disengage clutch
Rev motor
Engage Clutch
Shift into lower gear
Double clutching is done to match the rpms, incase you dont have synchronizers, or because its alot smoother.
And now onto what the other guy said. I was always told there are two ways to powershift. 1) (the ***** way ) where you keep the gas to the floor and clutch and shift as fast as you can or 2) ( the real way ) where you keep your foot to the floor and just slam it into the next gear.
I prefer the clutch ( ***** ) method, because its just a tiny bit easier on the car
Old Apr 4, 2004 | 12:45 AM
Vendetta's Avatar
Lol, too much F&F for you... double clutching is rev matching, doofus!!
Old Apr 4, 2004 | 12:59 AM
RedHottG2's Avatar
Alright, if that's the case I learn something new everyday. I give alot of people info. on here that that is right on target. So I appreciate you guys explaining my misunderstanding to me. Thanks guys!!
Old Apr 4, 2004 | 01:08 AM
Vendetta's Avatar
No prob
Old Apr 4, 2004 | 01:16 AM
yeah, sorry if i came across like an a-hole, it just pisses me off when i hear people at school or around here tell me double clutching is when you "have the clutch and gas down at the same time" And then tell me i am a tool for saying what i just said.
But on another note, has anyone ever powershifted without the clutch. My dad always makes fun of me for powershifting with the clutch, and i dont have the ***** to try what he says. And i dont think its worth it to waste your tranny trying to shift a tiny bit faster
