Power Door Locks Wont Unlock
Old Sep 12, 2003 | 12:25 PM
All4Chevy's Avatar
I had a problem awhile back of the driver side lock not locking when i pushed the button, and I just had to replace the little plastic switch because it was broken and wasnt pushing down all the way. For awhile my passenger side hasn't been unlocking the doors when the button was pushed, but the switch is in good condition. Now both doors will lock fine, but neither will unlock, any suggestions on how to fix this? Its annoying not being able to unlock the other door.
Bill
Old Sep 12, 2003 | 07:15 PM
96HealyZ28's Avatar
Is the fuse blown, Check the fuse marked courtesy. Mine blows all the damn time, I gotta short somewhere, dont know how to find it though, anyway, check the fuse.
Old Sep 13, 2003 | 04:05 AM
Fastbird93's Avatar
Via my 93 service manual, if a function like lock or unlock quits, possible cause is a faulty switch. I was having the same problem with one of my T/A's, and it was a bad switch on the driver side.
Old Sep 13, 2003 | 07:50 AM
InjectedSS's Avatar
i dunno wtf the deal is either... like all of the sudden one day my friggin driver side switch WILL NOT LOCK the doors.. i have to reach over to the passenger side to LOCK them i've tried replacing the switch and every stuff
I swear, the stupidest thing's go wrong sometime's
Old Sep 13, 2003 | 06:28 PM
Fastbird93's Avatar
When I had the problem with mine, it was the switch in the opposite side door of all things.
Old Sep 13, 2003 | 09:13 PM
All4Chevy's Avatar
Problem solved. I went out the next day it it all works fine again, maybe it was messed up because when the car was locked orginally i used the remote sensor and opened the passenger door and then tried using the lock from the driver door....but everythign works good now, so good times!
Thanks anyways,
Bill
Old Sep 13, 2003 | 10:26 PM
mdstud's Avatar
The door locks are wired in such a way that if one of the switches goes out, neither will work, thinks of it like a 2-way switch, when one leg is off the other is on, then when the one that is on goes off, the one that is off goes on... So I would just spend the money and replace both switches at the same time...
Heathen1
Jan 2, 2016 04:27 PM
EdgarArmada
Apr 18, 2015 05:20 PM
warmeck
Mar 24, 2015 10:52 PM
siguy
Nov 27, 2014 10:07 AM
XtremeLt1
Sep 13, 2002 08:50 PM
