power buttons
Old Jul 8, 2003 | 06:01 PM
windnsea00's Avatar
Question power buttons
the driver side window button and the button to lock the doors on the driver side both have broken. what's the best way to get this fixed? should i just try car parts for sale/car parts wanted forum and do it myself? thanks for any help.
Old Jul 8, 2003 | 06:06 PM
95DropTopZ28's Avatar
My door lock broke also. I never use it because of the keyless entry but the previous owner must have. It was the spring and I made a new one with piano wire from a hobby shop. You could also try a salvage yard
Old Jul 8, 2003 | 06:46 PM
Pandamonkey's Avatar
Is it just the top of the button that is broken, or is it the whole switch assmebly?
Old Jul 8, 2003 | 07:25 PM
windnsea00's Avatar
well for the lock button its just really loose and wont do anything and for driver window button i broke it off trying to figure out what to do.
Old Jul 8, 2003 | 07:56 PM
The switches are relatively cheap at the dealer. You cannot just buy the button shell, if that is what you need.
Old Jul 8, 2003 | 08:06 PM
Fear The Z's Avatar
i just broke my door lock switch on the drivers side...cost me only 6 dollars from the dealer.
Old Jul 8, 2003 | 09:12 PM
raceryan's Avatar
Same here. It's a cheap, easy fix.
Old Jul 9, 2003 | 02:03 PM
windnsea00's Avatar
if i were to purchase 2 new buttons, do they just snap back in place where the old one broke off?
Old Jul 9, 2003 | 02:39 PM
They are not hard to replace. You have to remove the little panel from the door and put them in from the back. Easy enough that I did my window switch in the dealer parking lot.
Old Jul 10, 2003 | 08:15 AM
raceryan's Avatar
yeah, theres 2 little tabs holding it in, and a plastic conector on the back of the switch. Pull off the connector, and use a small flat-tip screwdriver to release the holding tabs while pushing down on the top side of the switch. Once it out, press the new one up and in to the panel, plug up the connector and your good to go.
Old Jul 10, 2003 | 08:51 AM
coolgenner's Avatar
great help!
I just noticed mine was going bad last week. Thanks for the info guys!
Heathen1
Jan 2, 2016 04:27 PM
blmw
Jun 14, 2015 05:20 PM
tds1213
Nov 27, 2014 12:55 PM
XtremeLt1
Sep 13, 2002 08:50 PM
