Power antenna question.
Old Nov 26, 2003 | 03:32 PM
Eddie95Z28's Avatar
OK I just got the power antenna dealy at a real good cost. (thanks again Scott.) For my 95 Z28. I know the antenna goes up when the radio comes on... Now the question is does it go back down if I play a CD? Cause if it doesn't I am just going to wire a manual switch deal if I can.
Old Nov 26, 2003 | 03:35 PM
RamAir95TA's Avatar
Re: Power antenna question.
On Pontiacs, if the radio is on, the antenna will stay up.
Old Nov 26, 2003 | 03:43 PM
Eddie95Z28's Avatar
Thanks. I guess a manual switch is going to be the way to go. Does anyone know what voltage the remote signal is for the power antenna? I figure I can just run the orange antenna wire to the orange wire for the bose speaker in the hatch area. And then ground it. I should be set to go once I wire a remote switch in to the proper voltage.
REDNECKISBOSS
Mar 22, 2015 08:31 AM
siguy
Nov 27, 2014 10:07 AM
XtremeLt1
Sep 13, 2002 08:50 PM
97_396_WS6
Aug 4, 2002 10:23 PM
Red97LT1
Aug 3, 2002 07:29 PM
