potential flow #'s on stock castings?
Old Dec 3, 2005 | 07:43 AM
F(ast)-body's Avatar
what's the best flow numbers one can expect for a set of ported LT1 castings? I mean can they be made to flow 300 cfm or is that a little too much.....
Old Dec 3, 2005 | 08:25 AM
jkipp84's Avatar
Re: potential flow #'s on stock castings?
Some info for you:
http://web.camaross.com/forums/showthread.php?t=411824
Old Dec 7, 2005 | 02:08 AM
sbs's Avatar
sbs
Do a search. Plenty of people have posted flow #s.
Not sure if I've ever seen 300 posted for LT1 heads. I imagine you can with enough $$$.
Have seen several LT4 over 300.
Old Dec 7, 2005 | 06:12 AM
FASTFATBOY's Avatar
Yes, believe it or not, I have seen a set flow 308CFM. Car ran 10.40's with a solid roller, stealth ram intake at 3350 pounds.
David
Old Dec 7, 2005 | 09:43 AM
1redTA's Avatar
yeah but those heads have a ton of work done to them like offset rockers from where the intake ports were widend.. it can be done but you might be better of with afr's if you are looking for that kind of flow
Old Dec 7, 2005 | 09:52 AM
DarkHorse's Avatar
Why the interest in peak numbers?
I'd be a lot more concerned with the mid lift numbers than peak, unless your car is at the upper end 95% of the time it's running.
Old Dec 7, 2005 | 10:06 AM
METALBEAST's Avatar
Lloyd Elliot posted an interested thread about flow numbers and the importance of head design. Flow numbers aren't the only name of the game
Old Dec 7, 2005 | 11:16 AM
Tom Piper's Avatar
I've read in several places that the early ('92 and/or '93) LT1 aluminum heads had more material and could be ported out more.
Anyone ever confirm that?
Tom Piper
Old Dec 7, 2005 | 11:42 AM
IllusionalTA's Avatar
I do know that 300cfm can be had as said above but lot's of $$$. I think AI has a set of LT4's that peaked at 300+ or so.. But on avg 275's or so out of the intake of a lt1 casting is the norm...
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 25, 2015 12:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
