Post-cam install question
Old Aug 10, 2007 | 08:20 PM
95z28man's Avatar
What if I install my cam without using a degree kit beforehand, and the cam is off? Will a degree kit do anything other than check to make sure the cam is up to specs? What would I need to do if it doesn't run right?
I already know that if something does go wrong, I'll be posting a vid of the initial start up on the boards to see what you guys think (hopefully that won't be neccesary)
Old Aug 10, 2007 | 08:24 PM
wrd1972's Avatar
The degree wheel is used to measure or degree the cam, it is only a measuring tool. If the cam is off then its off and your screwed.
Old Aug 10, 2007 | 08:48 PM
95z28man's Avatar
So basically, I should save the money because degreeing the cam doesn't do jack other than tell me I'm screwed before I even get the car started.
Old Aug 10, 2007 | 08:51 PM
joeSS97's Avatar
Exactly,odds are that its fine.
Old Aug 10, 2007 | 10:12 PM
11secgen's Avatar
a degree wheel is used to make sure the cam timming is dead nuts on.things like timing chain stretch and align boring can affect valve timming.you may need to advance or retard your cam to get the valve to open exactly where they should.in most cases degreeing the cam isnt nessasary and just installing the cam at 0 deg is just fine.
odds are that its close enough.
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
nautilus
Aug 22, 2002 11:49 PM
Chrisdude
Jul 24, 2002 02:25 PM
Brent94Z
Mar 21, 2002 04:44 PM
