Post any numbers you have on "cam only" LT1 builds
Old Feb 11, 2008 | 04:34 PM
Rising Phoenix's Avatar
Just curious to see somes dyno #s and maybe track times for cam + bolt on LT1s, stock or close to stock weight.
Old Feb 11, 2008 | 05:12 PM
96capricemgr's Avatar
Friend has a cam only Caprice, stock weight 32-3300 stall 3.73s 28" slicks which are all wrong for the setup and it runs 13.5 even in 105F degree heat 4000ft. DA 87 octane full exhaust, belt on etc basically worst case scenario. Is a custom Advanced Induction grind similar to the HOT in duration, keep in mind he is severly lift limited by the iron heads and runs 1.52 rockers to keep lift down.
I had a 2800 stall 3.42 ZZ4 cam(208/221 .474/.510 112) in my Caprice that went 13.2 in a negative DA, my friend has a few pounds on me, big guy. Same conditions his would blown my old setup away.
Old Feb 11, 2008 | 05:59 PM
lt11997's Avatar
With the mods in my sig on a stock tune I put down 305 rwhp. With it tuned it will run 12.9s to 13.1s all day.
Old Feb 11, 2008 | 07:06 PM
lt1-xjs's Avatar
I know a guy who went 11.95 et with a 503 cam only in a 1995 camaro with an auto., along with other bolt on's, stall, gears, slicks, etc.
Old Feb 11, 2008 | 07:48 PM
Steve0's Avatar
Hotcam, stock rockers, mac headers, 3" exhaust, intake... through a 6 speed. 322rwhp/333rwtq on a Mustang Dyno.
Old Feb 11, 2008 | 07:54 PM
slomarao's Avatar
cam only cars are going to put down anywhere between 310-385 rwhp. This depends on if you running a hotcam or cc305 all the way up to a solid roller that decent sized.
If you search around, in the search section or just by looking about people sig's you ll find plenty.
Old Feb 11, 2008 | 10:18 PM
96supersport's Avatar
i would like to know what cam only set up can put down 385rwhp in an lt1
Old Feb 11, 2008 | 10:32 PM
ssbowtie1's Avatar
I think the most you'll see is 340-350rwhp on stock heads, but I'm always open for someone to prove me otherwise
Old Feb 11, 2008 | 11:22 PM
marshall93z's Avatar
He said solid roller. Not a problem.
Old Feb 11, 2008 | 11:27 PM
mdacton's Avatar
I did 340 and went 12.0
Old Feb 11, 2008 | 11:29 PM
Close to stock weight?
Old Feb 11, 2008 | 11:35 PM
mdacton's Avatar
me?
Well kind of...but it was a 1LE car.....it was 3150 with me in it. had ALOT of MPH. was a really good set-up for what it was. That was so long ago I forgot most of it. But it was stock rockers, small cam, stock intake and TB, longtubes with 3" edelbrock t304's, no PS, E WP, DR's, cut 1.70 60' and went 7.70's in the 1/8 I had been 92 in the 1/8 Was a m6 with 4.10 also 27" tire
Old Feb 12, 2008 | 08:58 AM
Z97LT1's Avatar
Mine made 358/370 with an xe224/236, 1.6rr's, MAC shorties, CAI, and catback. Only time at the track with this setup it went 12.98 at 112 in much less than ideal conditions on worn street tires.
I'm pretty confident that on better tires on a cool day without a 25-mph headwind it would have gone at least 2 mph faster.
Old Feb 12, 2008 | 09:25 AM
Now that's what I wanted to hear!
Just curious, were you running an electric pump or the stock style setup?
Old Feb 12, 2008 | 10:11 AM
Originally Posted by mdacton
me?
Cool. Damn that's light!
